Strange noise when sound is muted after installing intel ISST driver.
beeugene
System: Windows 10\11
Battery or AC: both
Model: rog Zephyrus m16 2021
Frequency of occurrence: constant
Reset OS: multiple times
Screenshot or video: https://disk.yandex.ru/d/GjNTt5Mutf4VJQ
Detailed description:after installing the intel ISST driver - a strange noise started to appear when the sound is muted and some kind of sound appears in the system (either playing video or some notification)
9 REPLIES 9
beeugene
GEEK_ASUS
Rising Star II
Hi there,
May I know your model name?
For the intel SST driver, please unintall the driver you are using, then refer to below link to download and install again.
ROG Zephyrus M16 GU603 | 2021 ROG Zephyrus M16 | Gaming Laptops|ROG - Republic of Gamers|ROG Global ...
beeugene
GEEK_ASUS
Hi there,
Hi! Thank you! The model is GU603HE-k8007. I've used the drivers from the site. Here is the installation sequence. The noise appeared after No 15_ISST driver.
GEEK_ASUS
Rising Star II
Hi there,
May I know your BIOS version?
Is the BIOS updated to the latest version?
