Serious issue with MediatTek Wi-Fi 6 mt7921 LAN card
System: Windows 11-Home, 64-bit
Battery or AC: Both
Model: FX506HM
Frequency of occurrence: Every 2-3mins
Reset OS: Done, I even reset my laptop!
Screenshot or video:
Detailed description:
I have tried almost every trouble shooting I have seen online, I am certain that this is a driver issue, I did the following:
Reset my Laptop but kept all the files, so after doing this my laptop rolled back to old drivers etc same when I bought it. I worked fine for at least 2-3 hours not until windows 11 auto update and this specific driver came back and started to be faulty again.
I uninstall and reinstalled the driver after downloading from myasus website.
I updated BIOS and firmware as well.
After all these troubleshooting steps, The issue still not solved. It's so frustrating.
Is there any solution?? Can I disable this driver and Install intel wifi driver? my laptop is 2021 Tuff F15
Falcon_ASUS
apolinariocarl
  1. System: Windows 11-Home, 64-bit
  2. Battery or AC: Both
  3. Model: FX506HM
  4. Frequency of occurrence: Every 2-3mins
  5. Reset OS: Done, I even reset my laptop!
  6. Screenshot or video:
  1. Reset my Laptop but kept all the files, so after doing this my laptop rolled back to old drivers etc same when I bought it. I worked fine for at least 2-3 hours not until windows 11 auto update and this specific driver came back and started to be faulty again.
  2. I uninstall and reinstalled the driver after downloading from myasus website.
  3. I updated BIOS and firmware as well.
@apolinariocarl
If you encounter this problem, please try the following steps.
1. Turn on the power and keep the battery power supply mode active (without plugging in the power adapter).
2. Press the power button for 30s to hard reset.
3. Enter the system and connect to the power adapter after it has rebooted.
4. Install MTK wireless network driver V3.00.01.1244 or above.
5. Install MTK Bluetooth driver V1.3.15.142 or above.
6. After the installation is complete, restart the device.
Please be sure to execute all six steps, updating the wireless network driver first, then updating the Bluetooth driver in order.
ASUS_Bot
Rising Star II
