Proart Studiobook 16 Oled H7604 4070 not an option on UK site?
Modobolton
It seems on the Asus UK site the only version of the Proart Studiobook 16 H7604 is the 4060 model with 1TB storage. Will the 4070 2TB model be coming back into stock or is it no longer an option?
Falcon_ASUS
@Modobolton
Product specifications for sale are mainly determined by business considerations based on local market demands in each region.
If you do not see relevant specifications on the website of your respective region, it means that those specifications are not available for sale locally.
Before purchasing a product, we also recommend confirming the actual shipping specifications with local dealers.
Thank you for your support of ASUS products.
It used to be there as an option and it still has the specs listed, but when you go on buy you used to be able select 1TB or 2TB and 4060 or 4070, the 2Tb amd 4070 options are no longer on the page. And the link in the image I've shared now takes you to the 4060 page, not the 4070 as listed.
Thank you for your help.
@Modobolton
This may be because the specifications you are looking for are sold out, and therefore, no additional options are available.
If you have any issues with purchasing the product, we recommend contacting local customer service or the purchasing platform.
The following is the contact information: https://www.asus.com/support/CallUs#
