low gpu usage and fps
anhquangno1
System: win10 64bit
Battery or AC: both
Model: fa706ii
Frequency of occurrence: frequently
Reset OS: none
Screenshot or video: yes
Detailed description:fps drop hugely during game.
as you can see from these pictures, my laptop can not play this game at 60 fps with this setting in control panel. The fps can even drop to 20 and 30 during some scenes. The gpu usage was only at 64 % which should be the cause. I have updated newest bios and gpu driver. I am desperate to find any solution. I got this problem since purchaseing this laptop and only updated window when it promted.
Blake_ASUS
Community Legend II
Please centralize your reply for better discussion.
