12-18-2025 06:04 AM
I am having issues running games on my ASUS Vivobook. It all started yesterday when I tried opening up FC 26. I received an error message stating that I had issues with my drivers and needed to update them. I did so, and while I was at it, I also updated Windows. However, now any game I try to run runs extremely slowly, with choppy/stuttering visuals. I checked the task manager, but everything seems to be fine; RAM usage is at nearly 50%, GPU usage is at 10%, and CPU usage is around 10-30%. I thought it was the Windows update, so I uninstalled it, and the issue still persisted.
My Specs are:
AMD Ryzen 9 7940HS w/ Radeon 780M
32 GB RAM
NVIDEA GeForce RTX 4060 Laptop GPU
12-18-2025 04:31 PM
@pikardenz
May I ask for the full model number of the laptop you are using?
[Windows 11/10] How to check the model name and BIOS version
Please confirm whether the BIOS version and system version have been updated to the latest.
Also, please verify if the installed graphics card driver was downloaded and installed from our official website.
If the graphics card driver was not obtained from our website, we recommend uninstalling it first, then downloading and installing the driver from our official download section. After that, please check if the issue has improved.
