[GUIDE] RGB Stuck on Static – Armoury Crate Fn+→ Fix (ASUS TUF F15 2022)
Infi0606
Author: Nikhil Kumar
Device: ASUS TUF F15 (2022, 10th Gen i5)
Issue: Keyboard RGB stuck on Static. Fn + Right Arrow not cycling lighting modes. Armoury Crate shows mode change, but keyboard stays static even after reinstall.
Symptoms
  • Fn + → not responding
  • Armoury Crate indicates lighting mode switch, but lighting remains static
  • Reinstalling Armoury Crate and Aura Creator didn’t solve the issue
Root Cause
This appears to be a conflict between Armoury Crate’s background services and the LightingControl module. It may be triggered by silent updates or corrupted leftover files from a previous installation.
Step-by-Step Fix
  1. Fully uninstall Armoury Crate
    • Use the official Armoury Crate Uninstall Tool from ASUS
    • Reboot your system
  2. Manually remove leftover folders
    (Administrator rights required)
    C:\Program Files\ASUS\ARMOURY CRATE Service
    C:\Windows\System32\ASUSACCI
    C:\Windows\ASUS
  3. Reinstall Armoury Crate cleanly
    • Download the latest ArmouryCrateInstaller.zip from ASUS support
    • Run as Administrator and reboot
    • Do not update Armoury Crate immediately
  4. Test RGB and Fn keys
    • Fn + → now cycles through lighting modes correctly
    • RGB changes are instantly visible in Armoury Crate
      Optional (Advanced): Prevent Future Auto-Breakage
      1. Block background update modules using Windows Firewall:
        ArmouryCrate.UserSessionHelper.exe
        ArmouryCrate.Service.exe This can help stop forced plugin updates.
        Disable automatic update tasks
        • Open Task Scheduler
        • Navigate to Task Scheduler Library > ASUS
        • Disable any ArmouryCrate-related tasks (e.g., UserSession, Update)
        Conclusion
        This method fixed my RGB lighting issue and restored Fn key functionality. Everything works perfectly after a clean reinstall. Manually blocking background update modules helps keep the system stable.
        I hope this helps other TUF users experiencing similar problems.
        — Nikhil Kumar
        Final Note
        Based on my experience, the latest version of Armoury Crate currently has several bugs and stability issues. Until ASUS resolves these problems, I recommend using a stable older version and avoiding updates for the time being.
0 REPLIES 0
