02-06-2023 09:55 PM
Hello!
My DTS:X Ultra app is not working anymore, it used to work but it doesn't anymore. I have reinstalled the drivers from the driver support site, no luck. Audio works but the DTS:X Ultra profiles don't change anything, turning DTS:X on and off doesn't even change the audio, the EQ doesn't do anything to the audio as well, nothing works.
BIOS 311
Windows 11 22H2
Solved! Go to Solution.
02-08-2023 05:29 PM
@Darkov
I have forwarded the information to the relevant department.
We will keep you updated and your consideration will be very much appreciated.
02-12-2023 06:13 PM
@Darkov
The technical unit said that we need your help to install the following two drivers to the following versions. Please go to the device manager to uninstall/remove the device, and execute the following exe. file , reboot the laptop, then confirm whether it works normally.
Realtek audio driver V6.0.9369.1
https://dlcdnets.asus.com/pub/ASUS/GamingNB/Image/Driver/Audio/28785/Audio_DriverOnly_DTS_ROG_Realte...
DTS Ultra LPAP Component Driver V1.10.19.0
https://dlcdnets.asus.com/pub/ASUS/GamingNB/FA506IH/DTS_Component_Driver_V1.10.19.0.zip?model=ASUS%2...
02-13-2023 03:09 AM
Thank you, the provided drivers fixed the issue, and DTS:X Ultra audio effects now work normally.
02-14-2023 05:18 PM
@Darkov
Thanks for the update.
08-21-2023 05:46 AM
