FX506H DTS:X Ultra not working
Darkov
Hello!
My DTS:X Ultra app is not working anymore, it used to work but it doesn't anymore. I have reinstalled the drivers from the driver support site, no luck. Audio works but the DTS:X Ultra profiles don't change anything, turning DTS:X on and off doesn't even change the audio, the EQ doesn't do anything to the audio as well, nothing works.
BIOS 311
Windows 11 22H2
1 ACCEPTED SOLUTION
Accepted Solutions
@Darkov
The technical unit said that we need your help to install the following two drivers to the following versions. Please go to the device manager to uninstall/remove the device, and execute the following exe. file , reboot the laptop, then confirm whether it works normally.
Realtek audio driver V6.0.9369.1
https://dlcdnets.asus.com/pub/ASUS/GamingNB/Image/Driver/Audio/28785/Audio_DriverOnly_DTS_ROG_Realte...
DTS Ultra LPAP Component Driver V1.10.19.0
https://dlcdnets.asus.com/pub/ASUS/GamingNB/FA506IH/DTS_Component_Driver_V1.10.19.0.zip?model=ASUS%2...
9 REPLIES 9
Darkov
Uhhh, sorry, my exact model is FX506HCB.
Falcon_ASUS
@Darkov
Could you please tell me what's the audio driver version and operating system build version you are currently using? Thank you.
Windows 11 22H2 22621
Realtek 6.0.9427.1
DTS 1.10.22.0
