Fans get stuck at High RPM
Deztructiv
System: Windows 10 home
Battery or AC: AC, so far
Model: GA503QM
Frequency of occurrence: Upon wake from sleep and during heavy usage
Reset OS: Started after factory reset
Detailed description: The fans on my new laptop were stuck at ~5400RPM (Both GPU and CPU, according to armory crate) after it was factory reset by the seller before purchase. It stayed this way the entire way through the setup process and remained after it was complete. I restarted the PC after setup to no avail. I updated everything I could find in MYAsus, Armory Crate and Windows Update. This included a bios update and updates to many drivers. After this it still persisted. I gave up and shut the PC down. After rebooting the PC the fans were operating normally. This was fine until I installed and started a game on the PC, after a while in the game the fans again went back to ~5400RPM and remained for hours after all applications had been closed and temperatures were low again. This same behavior, I have now discovered occurs after restoring from sleep as well. The only way to resolve this behavior is to "Shutdown" the PC and start it again, "Restart" does not help. I have looked in armory crate and MYAsus for settings. MYAsus points me to armory crate. In Armory Crate the profiles work well so long as the fans haven't gone into overdrive and the fans adjust accordingly. Even the max speed setting turbo has only reached 4200RPM fan speed for me so far. Once the fans take off to ~5400RPM the laptop stops responding to any profile changes in Armory crate. I have opened the UEFI to check for settings there but have not found any fan related settings available.
I have noticed online several other Asus laptops have this issue or something like it, even on this forum.
https://zentalk.asus.com/en/discussion/comment/170194#Comment_170194
https://zentalk.asus.com/en/discussion/47539/fan-speed-100-from-startup-but-myasus-says-the-fan-is-o...
Most fixes suggest 3rd party fan control software to override whatever software is going rogue with the fan speed. Which I can do, but I feel like this should not be necessary just to control fans on a new laptop. Others suggest opening the laptop and reseating cables, which I am comfortable doing but would like to know about any warranty implications before doing so?
I am prepared to take it back to the seller but they have no more boxed new PC's. From what I can tell from reading online this issue seems to be triggered after the first factory reset or after a bios update. So I will either be given a floor model (which will get factory reset) with the same issue. Or they will send it for repair, where all they will likely do is preform a factory reset shut it down and reboot and call the issue fixed only for it to reoccur as soon as I get it back. I have been down this route before and it is long and arduous and I would like to see if there is a possible software fix before I do this?
10 REPLIES 10
Blake_ASUS
Community Legend II
Hi there,
Thank you so much for the information.
I will consult more about this.
And please share if there is anything new.
Deztructiv
Yesterday, I woke up to the fans on my PC. At some point during the night the PC ramped up the fans to 6400RPM and it remained there until I awoke to the sound in the morning.
The computer had been put to sleep and the lid had been closed the night before.
So either the PC woke from sleep and started the fans or this happened while the computer was asleep.
We can now also conclude that the bios reset did not help.
Blake_ASUS
Community Legend II
Hi there,
Was the device hot at the moment?
If so, can you try to set the device to hibernate mode instead of sleep mode,
and see if the similar issue happen?
Deztructiv
The device is not typically hot when this occurs as you can see in the video I sent a while back.
Hibernate is disabled and the easiest way to get it to hibernate is to set a hibernation delay in the power options. I can set it up, and leave it to hibernate overnight. But I don't really see much reason to, I can basically already guarantee you that it won't happen in hibernation. Hibernation is the same power state as shutdown, except that the contents of the RAM is saved to the disk (see Wikipedia "Hibernation (computing)"). And so far, thankfully, I haven't had the PC start the fans when it is powered off.
I have a feeling that when I put the computer to "sleep" it is going into hybrid sleep as it instantaneously resumes.
I'd like to determine if this is a hardware issue (so I can work on getting a replacement), a firmware/driver issue (so that we might be able to get a patch since it seems to be affecting many people), or a software issue I can potentially fix myself.
Blake_ASUS
Community Legend II
I'm sorry that it's a bit hard to identify whether it is hardware or software.
There is a diagnostic tool in MyASUS. Please run the tool.
If there is no error message show, then it is more likely to be software.
