System: Windows 10 Home
Battery or AC: Bettery
Model: ASUS X73SV V1G
Frequency of occurrence: Allways
Reset OS: -
Screenshot or video: -
Detailed description:
The battery is dead. Shows 0% in Windows. Charging LED is lit but will flicker after a long time. It's probably the battery but it could also be some fault in the charging circuit on the laptop so it won't charge the battery. Therefor I want to probe the battery connectors on the laptop to see if there is any charging current. Can anybody tell me between which pins I can measure the charging current? See the picture.
