battery flat fast
wkchew
Batery flat very fast. Within 2 hour, the battery status from 100% to 64% . How to solve .
I open Whatapp web , Gamil and outlook . and without doing any window file.
Falcon_ASUS
@wkchew
May I ask which model of phone you are using?
I suggest trying to restore the system. If the issue persists, there is a higher possibility that it is caused by battery aging.
[Phone] How to do the factory reset on your phone
[Phone] Power saving tips
