BATTERY DRAINS VERY FAST!!
Saumajyoti
System: ASUS TUF F15
Battery or AC:
Model: FX506LI
Frequency of occurrence: Always
Reset OS:
Screenshot or video:
Detailed description:I have an ASUS TUF F15 FX506LI and the battery drainage is very fast. Also Diagnosed it and the battery is perfectly fine. But how fast the battery drains is very shocking for a brand new laptop, it cant even stay more than a hour in full battery saver with normal tasks like youtube and browsing at like 40% brightness. Very Disappointed from Asus. Pls I request to fix this issue with a software update atleast increase it to like 3hrs.
GEEK_ASUS
Rising Star II
Hi there,
Sorry to hear that you are facing the battery drain fast issue.
Please refer to below link troubleshooting steps for the battery life issue.
[Notebook] Troubleshooting - How to fix the short battery life problem | Official Support | ASUS Glo...
