ASUS Tuf FA566IV WIFI Problem My Wifi Disconnects automatically
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
04-07-2023 12:05 PM
I am Facing issue with Asus Tuf FA566IV Wifi Adaptor my wifi disconnects automatically and if i tried to reconnect again it shows cant connect to this network and if i switch off and on Wifi It shows No Available Networkd
Detailed description:
Hi, I’m having a lot of WiFi issues with a new ASUS TUF Gaming A15 FX566IV running Windows 11 (64bit).
The laptop came preloaded with a “Realtek 8822ce wireless lan 802.11ac pci-e NIC driver”
I will list the issues I’m experiencing below and also the actions taken so far to try and resolve (no success so far)
PROBLEMS:
- My wifi drivers would work properly before but now it'll suddenly disconnect by itself. The time is random, every few minutes or maybe longer after starting the computer, but it will still happen eventually. When I try to reconnect it says "Cannot connect to this network".
- When I try to turn the WiFi off and turn it on again, it doesn't show any available WiFi network (actually my WiFi modem still turning on and every another computer can connect).
i tried installing windows 11 again and formating all drives (clean installing windows and updating everything to latest)
but still problem cant fixed
similar issue to https://zentalk.asus.com/t5/others/tuf-a15-fa506ii-wifi-problem-losing-connection/m-p/138478
but no solution still
Can you please suggest me what to do
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-10-2023 07:03 PM
@Nileshmalav
Please refer to the following FAQ for troubleshooting.
https://www.asus.com/support/FAQ/1015073/
If the problem persists, I would suggest you bring back your laptop to our service center for further confirmation.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-21-2023 02:45 AM
