- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
06-20-2021 10:43 AM
Battery or AC: both
Model: ryzen 5 4th gen and gtx 1650ti
Frequency of occurrence: frequent
Reset OS: windows 10
Screenshot or video:
Detailed description:
I have been using the Asus tuf a15 for the past 1 year recently I have been noticing that in armoury crate the GPU fan section shows 0 rpm but I can feel the air coming out of the laptop, when I test it using my Asus app it sometimes shows there may be something wrong with your fan but most of the time it shows that the fan is working correctly
but the problem is that under heavy loads the fans won't speed up causing heating
what my be the reason for this problem is it a software issue or a hardware one
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-26-2021 06:55 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-26-2021 08:17 AM
zenflamerzzthis issue is very similar to mine but on a different Asus model , Currently i have completely reinstalled windows and upgraded to the new driver still the issue is not fixed for me
- System: Windows 10 Home
- Battery or AC:
- Model: ROG Strix G512Li
- Frequency of occurrence: Everyday since 3/1/2021
- Reset OS:
- Screenshot or video:
Detailed description:I just got my laptop for two weeks and two days ago (3/1/2021) the CPU fan has stopped working and it wont spin even when I switched to Performance and Turbo mode. My laptop getting hot easier when I play games. In the Armoury Crate, it shows "0 rpm" for my CPU fan spin rate, but sometimes it shows constant "63300 rpm" but actually it is not spinning at all (I can tell because there is no air generated at the left exhaust). Plus, when I ran the hardware diagnostic test, it do tell that I might have a problem with my fan
CPU fan(left fan) is not spinning on my ROG Strix G521Li
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-30-2021 12:45 AM
The air flow is not the indicator of the issue. The air flow can be directed to exhaust from the same side.
In all of your screenshot, the GPU is either not working or working in a very low loading,
so it is normal that the GPU fan is not running under those 2 scenario.
Do you have other concern or screenshot?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-02-2021 12:07 AM
recently it started showing such high rpm. is this some issue regarding the bios I am at the latest version 316. but this issue resolves quickly and will only shows up randomly
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-03-2021 09:24 AM
