ASUS FA506IV - Laptop monitor - generic pnp monitor
glondini
System: ASUS FA506IV
Battery or AC: AC
Model: ASUS FA506IV
Frequency of occurrence: since purchase
Reset OS: yes
Screenshot or video:
Detailed description:
When I go into Device Manager I see the Display Adapters configured fine but the "monitor" just shows as "generic pnp monitor" and I don't have 144hz refresh rate as an option. Does anyone know how to resolve this problem?
14 REPLIES 14
Blake_ASUS
Community Legend II
Hi Oliver,
There are 2 version of this model, one 144Hz one and and 60Hz one.
I would need your SN to check which one you have,
or you can double check your purchase record and detail.
Okay. Mine is 144hz 🙂
Blake_ASUS
Community Legend II
Hi Oliver,
So you don't have the option to change switch refresh rate?
May I have a screenshot and please double check if your BIOS and display driver are up to date.
Yeah. I Do have the option to switch between 144 and 60 hertz, but it still just use the generic pnp monitor.
I have tried to update, remove and install the display monitor. Nothing works for me.
Blake_ASUS
Community Legend II
Hi Oliver,
What's the problem of using the "Generic pnp monitor"?
