A15 FA506QM Shift Key combination not registered with some of other keys
System: Windows 11 Pro
Battery or AC: Both
Model: FA506QM
Bios Version: 311
Frequency of occurrence: Always
Reset OS: Reset and Reinstall
Screenshot or video: Yes
Detailed description:
Recently when I tried to use my laptop keyboard then I noticed some of the keys does not work with left and right shift. All this while I am using an external keyboard with no issues. Individually all the keys are working fine except some keys does not register when combine with left or right shift. I have escalated to APAC support but haven't receive any workaround on this except to hand in my laptop for further checking. I could not send it for warranty check as this is my main device for work purpose. Some of the things that I have tried:
Disabling sticky/filter key.
Reinstall keyboard driver
Reset windows
Reinstall windows
Clean keyboard contact ribbon
Test in safe mode / bios
Reinstall bios / downgrade / upgrade
Anyone have workaround this issue please assist.
Thank you in advanced
*Update FN + F11 (sleep) also does not work.
6 REPLIES 6
*sorry it seems like FN+F11 was disable in power setting.
Falcon_ASUS
almansuiskandar
  1. System: Windows 11 Pro
  2. Battery or AC: Both
  3. Model: FA506QM
  4. Bios Version: 311
  5. Frequency of occurrence: Always
  6. Reset OS: Reset and Reinstall
  7. Screenshot or video: Yes
  1. Disabling sticky/filter key.
  2. Reinstall keyboard driver
  3. Reset windows
  4. Reinstall windows
  5. Clean keyboard contact ribbon
  6. Test in safe mode / bios
  7. Reinstall bios / downgrade / upgrade
@almansuiskandar
Do you mean that when using an external keyboard, the FN function key of the built-in keyboard cannot be used normally? Or which keys of the built-in keyboard cannot be used normally? After removing the external keyboard, does the situation improve?
Please kindly provide the information below so that we can better assist you.
1.What system version are you currently using?
2.What is the model of the external keyboard?
Hi @Falcon_ASUS@Falco@Falco@Falcon_ASUS
My external keyboard works fine.
As for my built in keyboard, FN key are working fine, all individual keys are working perfectly.
What I meant was my laptop built in keyboard having the said issue with or without connecting any external keyboard. Shift key does not work with some keys, unable to capitalize some letters, and unable to register some symbol.
The image i attached above (in black shade) are the keys that does not stack with left and right shift key.
Sorry as I am unable to provide the system version now. Will do once I'm back at home.
Hi @Falcon_ASUS attached below my system information for your review. Thanks
