Thursday
i have purchased RT-AX58U V2 and the WIFI is capped at 3 mbps. The PC connected via LAN is doing okay but the other devices are not. Changing between control channels, 2.4/5/6 ghz bands doesn't affect the problem.
Thursday
Hi @thecatishere,
according to your question, please start by confirming the following troubleshooting steps:
Friday
1. I'm using the default settings with latest Samsung android device and latest MacBook Pro.
I've tried both 2.4, 5GHz bands with and without 802.11ax, on 20, 40, 80 and 160 Hz channel widths on different channels
2. Yes It's updated
3. I've restarted them multiple times
4. I've used basically every channel available for 2.4 GHz and also a lot of them in 5Ghz.
5. I bought the router yesterday it is with the factory settings
Friday
Connecting Wireless devices directly to the router results in ~3Mbps speeds, BUT connecting my laptop to the hotspot of my phone and then connecting my phone to the router results in acceptable speed on my laptop (~90Mbps) and ~3Mbps on my phone
Friday - last edited Friday
Ensure your router firmware is up-to-date. Reset network settings on affected devices, and check for interference from other electronic devices. If the issue persists, try resetting the router to factory settings and reconfiguring it. liteblueguide.xyz
