Wednesday
Just bought an Asus Zen XT8 router. I've been using Mullvad VPN. The instructions for configuring the two properly seem incredibly complicated to me. I've tried to follow them and failed repeatedly.
Is there any other good VPN which is simpler to set up with my router?
yesterday
Hi @richards1052 ,
thank you for your question.
In order to assist you better, could you please provide more details about the specific goal you would like to achieve?
For example, what function do you want to set up? What problem are you trying to solve or what outcome do you want to achieve?
Providing more specific information will help us provide more targeted assistance.
yesterday
I did succeed in connecting my router with my VPN via Wireguard.
But I'm noticing that when the router isn't connected to VPN it's twice as fast as when it is connected. I can't figure out why the speed degrades so much when I connect to the VPN. I want to use VPN. But I'd like to get similar speed when I use it. Can you think of any issue regarding compatibility that might be causing this?
