RT-BE92U Persistent Thermal Zone Faults
RicoSuave
First post here so bear with me if I miss anything. Since purchase, my RT-BE92U has been plagued with the same issues others have posted here. Up until the new firmware version dropped, I was having constant problems with network stability. I am currently running the latest firmware version (3.0.0.6.102_37435) and a lot of the issues seem to have been resolved except for one. Before the firmware update, I was seeing intermittent thermal zone errors in the system log. Since applying the update, I am consistently getting the following errors that appear every 3 seconds exactly:
Jan 4 18:29:52 kernel: read_bpcm_reg_direct_keyhole: Wait for completion failed, devAddr 0x3, offset 24, idx 2
Jan 4 18:29:52 kernel: thermal thermal_zone0: Failed to get RAIL 0 temperature, ret=256
Jan 4 18:29:52 kernel: thermal thermal_zone0: Failed to get temperature, ret=-1
Jan 4 18:29:52 kernel: thermal thermal_zone0: failed to read out thermal zone (-1)
On occasion, the errors coincide with a drastic decrease in wireless network performance. Under normal conditions, when connected to the 6GHz network, my wireless network download speed averages around 1100Mbps. This will drop to a nearly unusable 2-3Mbps. The 2.5GHz and 5GHz networks also see a decrease in speed to around the same 2-3Mbps. Wired clients seem unaffected. Once I perform a hard reset to the router, it seems to correct the speed issue for a while, but the thermal zone errors continue to persist. This seems to happen anywhere from once a week, to every day. Performing a hard reset isn't something I want to nor should have to keep doing to correct the issue every time it happens. Please let me know if there is anything else I can do to stop this from happening. I am getting very close to returning this router and exchanging it for a different brand. Thanks.
205 REPLIES 205
I wonder what has been changed as I don't see any improvement in stability at all. I'm getting multiple restarts a day.
stealththx
I ended up exchanging mine for the same model as I was still in the exchange period. I applied the 37506 FW to the new unit and no issues in a few days. Unclear if this new FW would have fixed the problem or there was a physical problem with the one I had. In any case, it’s fixed now. Last Monday I opened a ticket with phone support and submitted logs with a case number. Never heard anything back from support which is a little concerning though. I’d think a week would be enough time to respond to a ticket.
fairfacts
37506 solved the thermal logging.  I got one odd deauth at startup and a time clock error (NTP server is set so the time error was unexpected). Time is now good and I will monitor for the odd deauth errors that seem not to be connected to a MAC address (and for any reboots / drops) and report back if they appear in the (cleaner) logs
will_b
Does Asus have an email for customer support? All I see is a phone option and a chat option, and the chat option tells me to talk to best buy. I would rather avoid hanging on the phone for a long amount of time, but if that is their only other support option, I guess I will do that.
Hi @will_b ,
after updating the firmware, are you still encountering thermal issues, or is there another problem?
If so, please describe the issue in detail. Thank you.
