RT-BE92U Persistent Thermal Zone Faults
RicoSuave
First post here so bear with me if I miss anything. Since purchase, my RT-BE92U has been plagued with the same issues others have posted here. Up until the new firmware version dropped, I was having constant problems with network stability. I am currently running the latest firmware version (3.0.0.6.102_37435) and a lot of the issues seem to have been resolved except for one. Before the firmware update, I was seeing intermittent thermal zone errors in the system log. Since applying the update, I am consistently getting the following errors that appear every 3 seconds exactly:
Jan 4 18:29:52 kernel: read_bpcm_reg_direct_keyhole: Wait for completion failed, devAddr 0x3, offset 24, idx 2
Jan 4 18:29:52 kernel: thermal thermal_zone0: Failed to get RAIL 0 temperature, ret=256
Jan 4 18:29:52 kernel: thermal thermal_zone0: Failed to get temperature, ret=-1
Jan 4 18:29:52 kernel: thermal thermal_zone0: failed to read out thermal zone (-1)
On occasion, the errors coincide with a drastic decrease in wireless network performance. Under normal conditions, when connected to the 6GHz network, my wireless network download speed averages around 1100Mbps. This will drop to a nearly unusable 2-3Mbps. The 2.5GHz and 5GHz networks also see a decrease in speed to around the same 2-3Mbps. Wired clients seem unaffected. Once I perform a hard reset to the router, it seems to correct the speed issue for a while, but the thermal zone errors continue to persist. This seems to happen anywhere from once a week, to every day. Performing a hard reset isn't something I want to nor should have to keep doing to correct the issue every time it happens. Please let me know if there is anything else I can do to stop this from happening. I am getting very close to returning this router and exchanging it for a different brand. Thanks.
206 REPLIES 206
Tim69
37500 fixed my CPU core spikes.  I still had thermal errors popup.  I found issues with my WyzeCams and TP-Link devices using wireshark so I removed them.
I have not had any thermal faults since removing those strange outside connection attempts devices.  All radios are enabled with 36 devices connected.
TrappistOrder
im getting this same error and my router just updated to firmware 3.0.0.6.102_37506 but i cant find anything about the release and its not on the website.
Hello all, the latest firmware version 3.0.0.6.102_37506 has now been officially released.
Please update your device to the latest version and check if the issue persists.
ASUS RT-BE92U|WiFi 7|ASUS Global
If the issue still occurs, kindly provide a detailed description of the problem and submit a system report. After submitting the report, please send us a private message with the following details so we can assist you further:
  • Report date
  • Report time
  • Product serial number
Thank you for your cooperation and support.
After upgrading, the router reboot is still happening on a daily basis. Sigh.
Hello @changkai ,
we have sent you a private message.
Please assist us by checking the message so that we can provide further assistance. Thank you for your cooperation.
