RT-BE92U - On-going random losses of Internet/WAN access
AndrewMcN
I've had the RT-BE92U for a few weeks now and a couple of times a day it simply stops routing DNS WAN traffic and the Wi-Fi networks also stop routing. All Internet access grinds to a halt because of this. Sometimes it returns to normal on its own but today it was so inconvenient that I got it to reboot via the web UI. It's then fine again for several hours.
It's like the unit itself enters some kind of semi-hung/crashed state. I'm thinking there's some kind of memory leak or that the RAM capacity is insufficient. It runs for several hours and then begins going faulty.
I am 26 years into an advanced IT solutions architecture/engineering career covering pretty much all kinds of infrastructure. So, the most I'm guilty of is not trying the basics.
I am able to ping externally, however I tend to find that I cannot get DNS traffic to pass and that includes direct queries of external DNS services, e.g. 8.8.8.8 (I can ping this guy).
The Wi-Fi networks can't even reach the router itself. I have to go to my wired laptop to engage with the router. The router web UI responds normally. The system log just seems to show either long pauses between log entries or errors about wireless client disconnects.
This kind of error seems to be common in the log just now:
kernel: WLC_SCB_DEAUTHENTICATE_FOR_REASON err -30
kernel: WLC_SCB_DEAUTHORIZE error (-30)
Could be red herrings but they always seem to be around when the crashes happen.
I have a lot of smart devices. It says I have a total of 54 clients but the vast majority of those will generate very little traffic.
I use Sky Stream. So, there can be a lot of throughput there. I also watch a lot of Twitch. Again a lot of data passing through for that. Nothing I wouldn't expect this router to handle though.
I have AiMesh up and running with two nodes.
I use the Time Machine backup capability with a USB drive attached. There's an hourly backup.
I have the AiProtection turned on. DoS protection enabled.
I also have the DNS over TLS enabled opportunistically but I've tried putting this off and it doesn't help.
I just fear that the hardware spec isn't able to handle the workload.
It just seems like the firmware isn't stable enough yet. I need to decide if I should be returning this or just be patient and wake for the next firmware updates.
Anyone else with this router experiencing issues despite factory resetting?
56 REPLIES 56
Hi @AndrewMcN ,
thank you for your reply. Regarding the issue you mentioned, after updating to the latest firmware, the router has become unstable.
If you have already submitted the issue report, please privately message me the following information, and we will ask the team to verify it:
  1. Product serial number
  2. The time of submitting the issue report
  3. The email used for filling out the issue report
  4. The time when the issue occurred
  5. The device MAC address
If you have a network topology diagram, please also provide it to help the team better understand the current network environment. Thank you.
rickysuper
The latest beta firmware fixed many the bugs and please wait for the official release.
TonyGinSLC
You may want to check if you recently had a firmware update. I was having this exact behavior although I use a different model router. Call support and they know exactly how to resolve this.
itzilev
I have exactly the same problem except I'm runnig AP mode. Tried everything but no success. Start looking for return this device. I've shouldn't be changing my very best Netgear.
Current Version : 3.0.0.6.102_37025-g530f5da_954-gd3ae6_BB0B
Errors:
hamster76
I’m experiencing the exact same issue as you. Both the WAN and WLAN are entirely unstable and unusable, which is incredibly frustrating. I have to repeatedly reboot the system(including factory resetting) to get it working, and sometimes it takes several reboots before it functions properly. 😞
