09-16-2025 07:09 AM
I have had this router for about 2 weeks now. Randomly EVERYTHING drops and disconnects.
Firmware : : 3.0.0.6.102_38984-g8a9326f_1432-g7f449_BB0B
Sep 16 10:03:30 kernel: WLC_SCB_DEAUTHORIZE error (-30)
Sep 16 10:03:30 wlceventd: wlceventd_proc_event(645): wl0.2: Deauth_ind **:**:**:**:**:**, status: 0, reason: 4-way handshake timeout (f), rssi:-60
Sep 16 10:03:30 kernel: WLC_SCB_DEAUTHENTICATE_FOR_REASON err -30
Firmware is most up to date.
Router is all default settings.
Done 2 factory resets
This kills ALL wifi and Ethernet.
3.0.0.6.102_38984
09-16-2025 08:00 AM
Welcome to the forum and sorry to read of your problem!
Search for similar log lines has popped up a similar experience with a RT-BE92U way back towards the end of 2024:
I'm afraid at this point ASUS technicians should probably evaluate the firmware and publish one to prevent this from reoccurring.
Under Advanced Settings -> Administration -> Feedback (tab)
Please fill out the information as detailed as possible including the approximate time it last happened. (Ideally start the log right after a crash so you can note the time).
09-23-2025 03:48 AM
I also experience the same issue with the same router and firmware.
**bleep** shame since I just switched to this router to improve connection stability and now this happens...
09-23-2025 05:08 AM
Same, just got fiber and have had nothing but issues because of this crappy router. Their "support" has no clue and just says to return the device.
10-01-2025 11:58 AM
At this point, the best solution is to return to using the previous firmware update. This should restore proper operation.
