RT-AX58U cause outbound connection to remote server port 19883 fail
globerin
Hi , I can't connect to a remote server port 19883 using the router , If I connect using my phone(tethering) there is no problem. It's strange as far as I can connect to other servers using other ports ports like 10443.
Do you Know if RT-AX58U drops connections to a specific port range for outbound connections and how can it be solved.
Thanks.
0 REPLIES 0
