RT-AX82U
Razar
Hi, I wanted to know what mesh is compatible with the RT-AX82U? Thanks
Aureliannn_ASUS
Hi @Razar ,
according to your question, the RT-AX82U is a router that supports ASUS AiMesh.
Therefore, you can choose any ASUS router with the AiMesh logo to wirelessly or wiredly connect with the RT-AX82U to achieve seamless roaming and complete coverage.
You can refer to the product list of ASUS AiMesh routers and WiFi systems below to select the product that meets your needs.
Whole Home Mesh WiFi System - All series|ASUS Global
