rt-ax55 does not show log into router
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
12-09-2024 08:23 PM
When i log into the router with firmware 3.0.0.4.386_52332 and view the system log there iis no date and time of when the administrator logged into the router. This has got to be a flaw as the router shows all connections by the devices to other hosts but not a user connecting to the router itself.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-10-2024 07:08 PM
Hi @Asusme1 ,
regarding the issue you mentioned, we would like to confirm the following:
- In the previous firmware version, were you able to see administrator login information in the system logs?
- If so, could you please provide screenshots showing whether the administrator login information is present or absent in the new and old versions for our verification?
We will check with the relevant team. Thank you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-13-2024 04:54 PM
I have opened a ticket regarding this issue and it was lost. I have provided the logs in case N2411023123-0004.
This is a simple issue of logging into the router and viewing if the router shows the IP and the access is for administration purpose to the router as well as the time and date. Can you confirm that this exists for firmwre 3.0.0.4.386_52332 ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-25-2024 05:20 PM
Hi @Asusme1 ,
Thank you for contacting us.
Regarding your inquiry, we have confirmed the following:
The system only records the administrator's login time when the login fails.
If you are able to log in successfully each time, the system will not record the login time.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-19-2025 03:06 PM
This is an over sight since if a hacker gains access to proper credentials then the owner will never know who accessed the router.
