12-08-2024 08:23 AM
Hi
I have been having consistent issues with my Asus/Sky WiFi and recently inconsistency with Sonos and am getting very frustrated. Items lose connections and the Sonos now won't connect and it often drops the signal.
I have enough knowledge to think I'm dangerous but clearly not enough to solve the issue.
Configuration
Full sky fibre running the black sky hub
Sky Q and three mini boxes
Asus Mesh running in AP mode (3 x Asus XT8s and 4 x Asus XD5s) . (Still have sky WiFi running but only the sky boxes connected to that)
Asus does not handle DHCP as it is in AP mode that's all handled by the sky hub.
I have about 80 devices (ring, hue, Sonos, etc etc) connected by both WiFi and Ethernet.
I have a scheduled ASUS reboot every night.
I have read a lot about replacing the sky router with the Asus Zen WiFi but don't want to just keep reconfiguring stuff with no improvement. The 2ghz network from Asus seems to be very inconsistent compared to 5ghz network. And the sky q boxes run on 2ghz.
I have spent hours on this and rebooted, unplugged changed channels etc etc with no luck.
Any help would be absolutely amazing. I’m
12-25-2024 06:02 PM
Hi @acopland ,
Thank you for contacting us. To troubleshoot the network issue you're experiencing, we recommend trying the following steps:
1. Check the network environment:
2. Optimize router placement:
3. Update firmware:
4. Check device connections:
5. Limit 2.4GHz usage:
6. Test other channels:
