RT-AC68U VPN for a single device
Darnice
I have A RT-AC68U and I want to set up a Nord vpn and have only one device use the VPN, all other devices just access the internet. Is this possible?
jzchen
Zen Master I
I checked and this is a function of VPN Fusion, which I’m afraid the RT-AC68U does not support.
EDIT- The RT-AX68U has a BIOS update (3.0.0.4.388.21732) that supports VPN Fusion.
Aureliannn_ASUS
Hi @Darnice ,
based on your question, the RT-AC68U does not support VPN Fusion functionality.
You can refer to the following link and the supported devices list for more information. Thank you.
[Wireless Router] Why you must try Multiple VPN connection (VPN Fusion / VPN Client) - Later than 38...
ASUSWRT 4.0 (asuscomm.com)
