Dual band
Cas1111
I have a RT-AX82U dual band router. I want to use the 5g for everything EXCEPT FOR a bird feeder camera that only works on the 2.4g. I have set up the 5g network. Do I use the same steps for setting up the 2.4g network?
jzchen
Zen Master I
Yes you can.  Is there a specific concern you have in mind?
Aureliannn_ASUS
Hi @Cas1111 ,
Thank you for your inquiry.
Regarding your question about how to set up a 2.4GHz network, please refer to the setup steps in the FAQ below:
[Wireless Router] How to fix wireless Control Channel? | Official Support | ASUS Global
If the problem persists after following the FAQ steps, or if you have any other questions, please feel free to contact us.
Thank you for your cooperation.
