Can someone help me with drivers for Network/ASUS Routers?
welma
Can someone help me with drivers for my Network/ASUS Routers? I don’t see the latest drivers on ASUS website for some reason, and it looks like the latest drivers were from years ago? So strange.
Can you please help me? Help me by link me/send me the files for the latest firmware for ASUS RC1750 3.0.0.4.3.86 _51668 / RT-AC65P & for ASUS AX82U. The revisions should be 9.0.0.4.3.8.6.4.1.9.9.4 or newer. Can I maybe get help with download links for these drivers? If you could help me download the Merlin/dd-wrt driver versions that would be great!
jzchen
Zen Master I
BIOSes are region/country specific, as well as model specific.  RC1750-  Can you please correct that?  Any BIOS starting with “9” are beta level BIOS which may subject your network to instability.  I’ve never tried Merlin firmware nor DD-WRT I’m afraid, I suggest you try ASUS firmware starting with “3” for now.
alinah
You can use the driver updater tool, it updates all outdated drivers automatically and notifies you when the drivers get outdated.
Aureliannn_ASUS
Hi @welma ,
based on your issue, may I ask whether you want to update router firmware?
For RT-AX82U the latest firmware is 3.0.0.4.388_24231 release on 2023/11/16
RT-AX82U|WiFi Routers|ASUS Global
For RT-AC1750 the latest firmware is 9.0.0.4.382.52503 release on 2021/02/05
RT-AC1750 - Support (asus.com)
For RT-AC65P the latest firmware is 3.0.0.4.382.52516 release on 2021/03/09
RT-AC65P|WiFi Routers|ASUS Global
