AXE6600 ET8 6Ghz issue
Cdamania10
Hello All, I am facing a weird issue. I have 4 Asus ET8 setup as a route and yhe rest nodes. Back haul via ethernet connected to a gig switch. It use to work perfectly where all the bands were showing. 2Ghz, 5Ghz and 6Ghz and I had my phone connected to the 6Ghz and showing 6E and if I would move around the house it would transfer the phone to different nodes. Recently I started noticing that even though the wifi 6Ghz is enabled only the ET8 that assets as the main router works with 6Ghz the nodes don't work for 6Ghz it will not display it but setting shows that it's enabled and on.  When I go close to the main router ET8 it connects to 6Ghz instantly. Not sure what is happening and my suspension is something was messed up.after a firmware update came thru. Any assistance would be appreciated. I did a factory reset and still the same.
77 REPLIES 77
Hello KD67 how many total nodes do you have including the router. Also when you did the revert back did you do 1 at a time or is there a option to do all at the same time..
So I downgraded to the mentioned firmware on all nodes including the router and doesent seem to have resolved the issue. Do I need to do anything special after reverting the firmware back. I rebooted as well.
CKYY
ET12 node connect internet and mesh with two ET8 nodes (HW version 1.0). Same issue here after updating latest firmware of ET12 and ET8. 6Ghz didn't work in two ET8 nodes but no problem in ET12.  2.4Ghz and 5Ghz still functional in two ET8. Didn't resolve even downgrading ET12 and ET8 firmware to previous version. Waiting for firmware update to resolve this issue...
Edfluke
I have the same issue. It's been driving me nuts. "Main" router has 6ghz but the nodes do not.  Have done hard resets, checked router firmware etc.  Nothing fixes it.  I've also submitted a ticket and logs.  Asus please investigate.
While you guys wait for the proper repair, have you tried switching the nodes to Access Points?  (Then turn on WiFi Agile MultiBand).
