AXE6600 ET8 6Ghz issue
Cdamania10
Hello All, I am facing a weird issue. I have 4 Asus ET8 setup as a route and yhe rest nodes. Back haul via ethernet connected to a gig switch. It use to work perfectly where all the bands were showing. 2Ghz, 5Ghz and 6Ghz and I had my phone connected to the 6Ghz and showing 6E and if I would move around the house it would transfer the phone to different nodes. Recently I started noticing that even though the wifi 6Ghz is enabled only the ET8 that assets as the main router works with 6Ghz the nodes don't work for 6Ghz it will not display it but setting shows that it's enabled and on.  When I go close to the main router ET8 it connects to 6Ghz instantly. Not sure what is happening and my suspension is something was messed up.after a firmware update came thru. Any assistance would be appreciated. I did a factory reset and still the same.
84 REPLIES 84
Weird. Mine didn't flip on. Yet. But I'll keep monitoring.
SpaceAntelope
Yeah it’s not flipping the auto update on….its just installing the new firmware despite it being off.  I’ll check the settings and sure enough, the new firmware is installed by the next day.
Give this a shot. I noticed when I factory reset my devices my auto update was turned off. I triggered it on them off again. Give that a shot.
kaho0505
Tried the method on page 14, 6ghz works on all nodes perfectly now.
Warm Reminder: All nodes need to connect main router's lan port, otherwise it won't work.
Chingaso
Tried the newer rollback suggestion and, after a system restart, have 6e broadcasting from my ET8 node. BTW, I did not roll back the main router (gt-axe11000). Thanks for the solution!
