10-05-2024 06:11 PM
Hello All, I am facing a weird issue. I have 4 Asus ET8 setup as a route and yhe rest nodes. Back haul via ethernet connected to a gig switch. It use to work perfectly where all the bands were showing. 2Ghz, 5Ghz and 6Ghz and I had my phone connected to the 6Ghz and showing 6E and if I would move around the house it would transfer the phone to different nodes. Recently I started noticing that even though the wifi 6Ghz is enabled only the ET8 that assets as the main router works with 6Ghz the nodes don't work for 6Ghz it will not display it but setting shows that it's enabled and on. When I go close to the main router ET8 it connects to 6Ghz instantly. Not sure what is happening and my suspension is something was messed up.after a firmware update came thru. Any assistance would be appreciated. I did a factory reset and still the same.
01-18-2025 05:49 AM
Thanks. I'll give this a shot.
01-26-2025 04:30 AM
Hi, I tried your method and 6ghz works on all nodes now! Thank you very much.
*Warm Reminder
All nodes must need to use lan cable to connect with main router's port, otherwise it will not work!
01-18-2025 04:13 AM
Update: in addition make sure you turn Auto Update OFF!
01-18-2025 04:19 AM
Thank you. Will apply your steps and see if it is successful on my side as well. I did the same originally as to what you did and it was not working but will follow all the steps correctly. Will let you know how it turns out.
01-18-2025 08:25 AM
Good luck…if you didn’t know you can bind clients to a particular router / node in the mesh tab.
