ASUS RT-AX88U Mac Filter Auto Disabled
FelixYHM
Hi
Why my Mac Filter always auto disabled as well as the auto turn on of the Hide SSID.
I Unhide SSID and Turn on Mac Filter but it always being automatically reverse for my above product.
jzchen
Zen Master I
Is firmware up to date, Ver.
3.0.0.4.388_23748?  If you have updated firmware recently try a hard reset?
Aureliannn_ASUS
Hi @FelixYHM ,
based on your issue, may I ask have you make sure the firmware is at the latest version as @jzchen mentioned?
May I ask when did this issue occur?
Have you tried changing your WiFi password?
We suggest you can also try changing your router's password.
Have you recently been browsing or have any unauthorized devices connected to your network?
You can check on this.
