Monitors
Forum Posts
Vertical lines XG27WCS
There are vertical lines flickering when G-SYNC / VRR is enabled. It only happens with 3D applications and not when playing videos, so it can't be the hardware. I got my unit replaced and can observe the same issue with the new one. Monitor firmware:...
TJMGG by Star II
  • 44 Views
  • 0 replies
  • 0 kudos
Monster Hunter Wilds Promotion Issue
Currently its been a few weeks after I purchased the XG32WCMS monitor with the included Monster Hunter Wilds Go! But at the moment, it reads that the promotion should last from February 21st to March 31st, but that it is closed... Can anyone help wit...
Blego by Star I
  • 306 Views
  • 5 replies
  • 3 kudos
PA279CRV Color Calibration, Chroma Tune
I'm looking into trying to color-calibrate my PA279CRV monitor. I saw that it isn't supported by ProArt Calibration, and instead uses Chroma Tune. However, I can't find the Chroma Tune software anywhere, nor can I find any documentation on whether th...
Monster hunter wilds promotion
Hi,I bought an Asus VG34VQL1B Monitor and should be eligable for the MH:Wilds promotional key but can't claim it, I can attach the invoice to this. Let me know what to do.Thanks!
Begorra by Star I
  • 164 Views
  • 1 replies
  • 0 kudos
Uniformity compensation
I have new Asus PA32UCXR for photography editing. When i set ON Uniformity compensation, then this hapen. Right corner get pink cast. When i turn OFF that function, picture is great. I thought,..this function should make brightness and colors more un...
XG32VC是否可以換底座
最近Rog Strix有出ROG Strix XG32WCMS發現2024的顯示器出了平面式的底座,想詢問是否有辦法購買並更換XG32VC成平面式的底座。
JimmyL by Star I
  • 72 Views
  • 0 replies
  • 0 kudos
