Phone Idle - high battery drain (almost 30%)
jendrzew
Hello there,
I've been experiencing (since last week i guess) some big usage (28,5%) of "phone idle" in my battery usage menu. I havent changed anything since last time my battery was doing allright. Have all updates, last one is 31.1010.0411.138. Also my "screen" usage - 12,0%, system UI (11,2%) and google play settings (9,2%) have incredibly high usage too. Have anyone there had same issues lately?
Blumi
Rising Star II
jendrzew
Hello there,
Hi there,
Ive had the same issues. It is due to a faulty google services application. Check the thread on the location icon never disappearing: you have to remove the Google play update and reinstall it from store. Afterwards it will work again.
I went down to 5 hours of SOT - after doing the stuff above I went back up to my usual 8 hours
