Need help with fingerprint
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
06-28-2022 02:24 PM
Model Name:Rog Phone 5s
Firmware Version: 31.0810.1226.92
Rooted or not: not
Frequency of Occurrence: permanent
APP Name & APP Version (If your issue relates to the app): fingerprint sensor
I broke the screen of my Rog Phone 5s so I found a cheap Rog Phone 5 with a dead motherboard. I replaced the dead motherboard with the one from the phone with the broken display. Everything works perfectly apart from the fingerprint sensor. the sensor is connected and the test in the test menu is passing. The problem appears when I try to add a fingerprint - no matter how I place my finger it's not registered. The white dot lights up, but the sensor doesn't register my fingerprint. What can I do to make it work again?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-29-2022 03:58 AM
dixingo31.0810.1226.*"92"*!!! is there a new firmware?Please tell us some basic information before asking for help:
- Model Name:Rog Phone 5s
- Firmware Version: 31.0810.1226.92
- Rooted or not: not
- Frequency of Occurrence: permanent
- APP Name & APP Version (If your issue relates to the app): fingerprint sensor
I think a recalibration is needed, you need a tool and software, the software is from December 2021, I have no idea if it works with Android 12
Here is an example of the tool and a discussion on XDA
Otherwise if you have an ASUS repairer nearby it's fast and cheap
https://uk.aliexpress.com/item/1005003640410708.html?gatewayAdapt=glo2eng
https://forum.xda-developers.com/t/asus-rog-3-rog-5-rog-5s-fix-fingerprint.4355499/
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-30-2022 07:33 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-30-2022 09:00 AM
While waiting for you to have an answer from Asus, do you remember if you had reached the maximum (5) before the breakage of the screen?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-30-2022 09:54 AM
Our local Asus repair shop is a contractor which I think will not even try to solve the issue as soon as they understand that something was done with the phone.
