Dual band WiFi (5.8 ghz) is not supported in Max Pro M2
Dual band WiFi (5.8 ghz) is not supported in Max Pro M2. Is there anyway that can be fixed?
0
Comments
I guess it can't be fixed. Asus has done very silly mistake by not providing such feature.
Hi indyj7717
Thank you for your asking. Which country do you locate? I will check the device spec for you.
Nope. This device support only "WLAN 802.11 b/g/n 2.4GHz".
That's not surprising a lot of phones only have the 2.4 radios these days
India. I've checked it only supports 2.4 ghz. I'm just asking if it can be fixed if Asus provides an update.
Hi indyj7717
Thank you for your asking. "Spec" is a hardware thing, which can not be improved by software update.
Okay thanks. I suspected that.
