irremovable notification panel at Max Pro M1
Hey team why at 438 version of Android 10 this all notification is always show after completing all setup at my device please if it is a bug so fix it in next update....
Thanks.
0
Thanks.
Comments
How did you change the time format to PM ? Mine is in small letters
Thank you for your asking.
The irremovable notification panel is a default setting of Android 10 AOSP. Thank you.
https://zentalk.asus.com/en/discussion/37072/am-pm-in-caps
Mine after adb uninstalling of settings suggestions. Mind you search bar is also integrated with it. So that too gets removed.
The suggestions are default AOSP behaviour, not a bug.
