Android 10 438 build Asus Zenfone Max Pro M1
- Model Name:
- Firmware Version:
- Rooted or not:
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
Hi Team,
I am on Android 10 build 438.
Font setting and Icon shape style from developer option resetting after reboot...
Please Check.
Comments
Developer options are not recommended for daily usage.
Lol...those are customisation options..not experimental features..and They should work as per " DEFAULT AOSP BEHAVIOUR"..
It's not getting reset in my device after reboot.
Just now I rebooted by changing the font and icon shape.
Info: There is a little lag in screen performance after changing the Icon shape from Developer options.
Asus Mods, I'm not complaining about this since, it's not customization given by Asus.
