Maxpro m1 bugs sound A10 build beta 438
rumputliar30
Model Name:max pro m1 zb602kl
Firmware Version:android 10 beta 438
Rooted or not: no
Frequency of Occurrence:
APP Name & APP Version (If your issue relates to the app): sound bugs
I try update from 087 to 438 beta. Sound quality bugs never fixed. Lazzy developer,i really hate this suck phone. Madar chod..!!!!
I use USB dac and poweramp. Sound very suck like making from kids developer. Bass frequency like a shit,treble like a crap.
I am waiting 2 months for new update and you give me a shit update.
Fix your audio tuning sound quality. Stupid!!!
Yachendra
Rising Star II
rumputliar30
  1. Model Name:max pro m1 zb602kl
  2. Firmware Version:android 10 beta 438
  3. Rooted or not: no
  4. Frequency of Occurrence:
  5. APP Name & APP Version (If your issue relates to the app): sound bugs
Meanwhile you can uninstall icepower app using adb. You will get proper bass with decent sound.
ZT-dec80e76
I m facing with the similar problem with earphone crack sounds nd the opposite side person not getting my voice over the call or games. Plss let me know if you get some solutions
Yachendra
Rising Star II
rs6854455@gmail.com
Do SIMMI test for BoardMic, If it get fail then do the factory reset of device and check. If still not working then your mic would be problem.
