Audio Volume to max and Brightness to minimum issue
in ROG Phone 3
- Model Name: Rog phone 3
- Firmware Version: .99
- Rooted or not: Not
- Frequency of Occurrence: Frequent
- APP Name & APP Version (If your issue relates to the app): Everywhere
In some situations Brightness go to minimum and Volume to max:
-deactivating the X-mode 100% of times
-unplugging the charger 50% of times
-frequently also when using home or multitasking gestures or when closing apps
-using floating apps from game genie
-sometimes it happens randomly witbout doing anything
This is one of the most annoying bugs of the phone and I hope someone can confirm this because it needs a fix and fast.
0
Comments
It isn't necessarily a bug,It must be your settings more likely because I have a similar problem
I have so many different settings and optimizations for games and apps that If anything closes or changes,the settings will either change rapidly or the adaptive brightness will take control
What I'm trying to say is that the brightness is controlled by the environment on most occasions and that perhaps you have a lot of different settings for many apps and they just get turned off or on, especially with the X mode
Again not necessarily a bug
Another guy helped me to find the solution, it was caused by custom battery mode, I went back to default settings and now it's finally ok, it was a very annoying problem
Close the thread, problem solved
@simo97.codega Good to know you found a solution to your issue. I'm closing the thread.
