Unexpected extreme battery drain
- Model Name: Rog Phone 2
- Firmware Version: WW_17.0240.2009.49_0
- Rooted or not: no
- Frequency of Occurrence: Every day since a week or so
- APP Name & APP Version (If your issue relates to the app):
Hi everyone, since a week (more or less) I'm experiencing a very fast battery drain. It happens also in standby while doing nothing. The strange thing is that I haven't done any firmware updates and I haven't installed any new apps since weeks, so I don't understand what could be happening. The battery usage stats don't show what is draining the battery. Here is a screenshot:
Can someone help me?
Thanks,
Andrea
Comments
Do you get the same issue when lowering the refresh rate?
It is probably worth doing battery calibration.
I agree. I regularly do battery calibrations. I usually get around 9-10 hours screen on time at 120hz with the latest update. Which is almost identical to what I received on Android 9. The latest update is stable. I actually have difficulty draining the battery with these settings, playing call of duty mobile 2 hours a day, within 24 hours. See if it's possibly a app draining the battery. Because it definitely isn't a system problem
