My ux433fn mount an Intel 620 GPU + an nvidia geforce MX150. Looking for GPU specs on manufactures website i can see that the max resolution supported is [email protected]
So, if it is as you say, it means that you are deliberately blocking and limiting the resolution for external displays. If so it would not be correct!
a thunderbolt that don't allow to use external monitor over usb
driver issue caused by the last nvidia driver you have released, I had to go back to the previous version due to continuous BSOD)
impossibility to connect an external wide screen with more resolution than 1920x1080px
a laptop that after a year has lost half of his value
... and yes, you continue to call it an ultra book.
For a long time I have been fascinated by zenbook, but unfortunately your product is not of good quality and also it is not a top product. I will never buy asus products again.
about your other topic "ux433fn with wifi intel AC 9560" , your wifi still working ? Do the problem start again ? I was okay for few month, but after one windows update, again my wifi is not working every start.
I literally tried everything, I notice there is a problem with the bluetooth driver, but every time I try to uninstall bluetooth driver in device manager, windows reinstall it...
Very hard to make people understand this problem, you are the only one I found explain exactly the same problem I have, thanks a lot for you help
Comments
Hello AleeeKoi,
It's 1920*1080,60Hz.
Sure? Why does external monitor couldn’t reach more resolution? I need to connect a 21:9 monitor with an higher resolution......
Hello AleeeKoi,
It is the maximum signal that can be exported. Thank you.
Wait a second...
What is the version of the HDMI port installed?
Hello AleeeKoi,
This model is having HDMI 1.4.
Hello,
Formats supported by HDMI 1.4 include:
So, aside from the fact that hdmi 1.4 is a 2002 format... why don't you support 4k ?!
Hello AleeeKoi,
To keep balance of stable function on all parts, 1920*1080,60Hz is the maximum for this model.
So, at now I have a ux433fn with:
Well done asus. Congrats.
I use 4k on 30hz. no problem
60hz is not possible.
Hello Aleeekoi,
