Caddy get power cut when booting on battery and others
- System:
- Battery or AC: X555-48
- Model: ASUS X555Q
- Frequency of occurrence: When I boot my laptop using battery and restart from Manjaro Linux
- Reset OS:
- Screenshot or video:
Detailed description:
So recently I have buy an SSD, change my optical disk drive with HDD caddy with the HHD I have. And I face several issue
- When I restart my laptop in Linux Manjaro, I heard the HDD power has been cutted (You know, the sound of a HDD when you force turn off your laptop). But it does not apply in Windows
- When I try to boot my laptop using the battery (Without connecting my laptop to an external power), I heard the HDD power has been cutted and after a few seconds the machine starts running
I have read some article that mentions the negative impact from cutting a power from HDD and I don't want it happen to my HDD. Do you know what's the cause of my problem? And how do I fix it?
Comments
I suspect that HDD caddy is the main problem and also HDD slot is not properly seated in HDD caddy slot.
