Android 10 for Asus zenfone Max pro m1
kumariveena981kumariveena981 Level 1
edited September 2020 in ZenFone Max Pro Series
  1. Model Name:Asus zenfone Max pro m1
  2. Firmware Version:
  3. Rooted or not:not
  4. Frequency of Occurrence:
I actually upgraded to the beta version of Android 10. I found some good things like phone boots up faster. The new dark mode is amazing. And the notification bar icons are pretty good. The sound quality in pubg is awesome. It also supports internal audio recording using ADV screen recorder.
If you are just a normal guy who play pubg just for fun not at competitive level(customs) and uses phone like in daily life . Go ahead and update this. This will erase your all data so make sure you backup. The most important thing is battery drain is very low because of dark mode.
But pubg mobile not supports graphics over balanced at medium frame. But we use GFX so there is no need to worry.
What you think let me know
Comments
