Asus TUF Gaming A15 keyboard light and fan mode setting problem
- System: Ryzen7 4800H
- Battery or AC: Battery
- Model: FA506 II
- Frequency of occurrence:
- Reset OS:
- Screenshot or video:
Detailed description:I faced a problem which the keyboard light setting ( fn + arrow up / arrow down ) and the fan mode setting ( fn + f5) fail to respond. This happened when I got press these setting at the login page ( page where i type password), even after that i done login afterward but these setting will fail to respond and i am forced to restart the laptop to solve the problem
Any one can help solving these problem ?
Comments
Hello zhixiangeo,
May I know when did this issue started? from the beginning you have the laptop?
Also, if you do not adjust anything at the login page, after you enter the system, do the keyboard and fan setting work?
This issue started yesterday.
if i do not adjust anything, the setting does work as usual.
Hello zhixiangeo,
Any adjustment or update on the day before?
I have the same issue on my ASUS TUF Gaming A15. It just started last night
Hello blake
No update or adjustment before it. Thanks
Hello zhixiangeo & labar.paul,
Thank you for your feedback,
I have reported this issue to related department.
Will keep you updated.
Hello blake,
Thanks for assisting.
hello,
i have the same probleme with my tuf705, it happen after a windows 10 update, and i cant go back to the last version of windows because it was 10 days ago and windows dont allow to restore to the previous version after 10 days.
sorry for my bad english im french
Hello Arnaud,
Please kindly check if your BIOS is up to date.
And please reinstall ASUS Keyboard Hotkeys
hello,
i did nothing and today the keyboard and fan control started to work.
thank you
Hello Arnaud,
Thank you for the update.
Glad to see this.
Eso ocurre por tener activado el inicio rapido de Windows, al desactivarlo se soluciona completamente ese problema
