Zenfone Max Plus Stable Pie Build
Xavier
Will ASUS release a stable Pie Build for Zenfone Max Plus (ZB570TL)? Its been months since the beta build and there are no updates.
4 REPLIES 4
jeff63355
Unfortunately, Asus ended the support and updates on this device. They only support and give updates to devices for 3yrs from its release date. Max plus was released on 2016.
Xavier
Ummm, as far as I know, this model was released by December 2017, not 2016...
jeff63355
My bad, not sure where the 2016 came from. Anyways, I doubt that they'll give updates anymore. If they ever give one, it'll probably just android 10 AOSP just like what they did with android pie AOSP. Then eventually releases a downgrade for it. sigh
kikoly
Hall of Fame II
It has been confirmed that ZB570TL has been updated and maintained for more than 18 months and will no longer be updated and maintained.
The official statement refers to the following link:
cliffwar
手機型號: ZB570TL
記憶體: 3G
韌體版本: WW_15.02.1904.543-20190509
是否有Root: 沒有
出現頻率:
APP名稱:
本帖最後由 cliffwar 於 2020/3/15 22:46 編輯
請問我手機目前的版本是去年更新的WW_15.02.1904.543-20190509 這個版本是否有安全問題,
有問題的話 是否有更新檔可以手動更新?
請問有關3 月的 Android 資安報告,其中的一項漏洞 CVE-2020-0069
