When i press the power button for screen lock it automatically off the phone.
margatehani
Model: ZC550KL(Max)
RAM: 2G
Firmware/APP Version: screenlock
Frequency of Occurrence: screenlock
Rooted: No
APP Name: Screenlock
4 REPLIES 4
ServiceE_Asus
Hi margatehani, Good day. Do you long press the power key or not? If not, please kindly help me check this matter under safe mode. (For instructions, please refer to the link: http://www.asus.com/zentalk/forum.php?mod=viewthread&tid=3105&highlight=safe%2Bmode) If this problem still appears, this might be a hardware issue, I would suggest you bring your phone to a local service center for a check. Sorry for any inconvenience this may cause. http://www.asus.com/support/Service-Center-All-Countries/
margatehani
Just a short press. As long as the screen goes off, phone automatically turned off. Then if you turn it on battery life decreases about 15%. What a waste.
margatehani
Emilee_ASUS posted on 2019/5/21 17:33 Hi margatehani, Good day.
Btw. Theres no safemode for 5.0.2 And I cant install the unlock device tool. Says "parse error".
ServiceE_Asus
Hi margatehani Thanks for your reply. The power button might be caused by a hardware issue, I would suggest you to backup phone files and bring your phone to a local service center for a further examination. Do you use this Version 8939 of UnlockTool? https://www.asus.com/Phone/ZenFone-Max-ZC550KL/HelpDesk_Download/ Please show me your error screenshot and show me your serial number by PM. (settings> system> about phone > status > serial number) Thank you.
