Hi
kcrkindiaThank you for your asking. Kindly try some stay-at-home troubleshooting tips below:
1. Please try reset Network: Settings>System>Reset options>Reset Wi-Fi, mobile & Bluetooth
2. Please try to enter "Safe Mode". If the function works well in Safe Mode yet the issue remains out of Safe Mode, please check on any disturbance from the installed 3rd party apps.
https://www.asus.com/support/FAQ/1005163/3. Also, please try "the Factory Reset"
Settings>System>Reset options>Erase all data(factory reset)
Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
4. If the issue persists after the Factory Reset, please try SMMI test
Calculator> type ".12345+=">SMMI TEST>Single Test>SIMCard Test/SIM Signal Test/Wi-Fi Test
If any of the SMMI tests fails, kindly bring your device to the nearest ASUS repair center for device checking:
https://www.asus.com/support/Service-Center-All-Countries/If it is impossible to access the service center during Covid-19 period, please try Call us:
https://www.asus.com/support/CallUs
