Rhenz04
How to Disable Reverse Charging.
Check the power source.
Check your charger port/cable by charging another device(s).
Try to charge your phone with another charger port/cable.
Factory reset/Hard reset.
In case the problem still appear, try to flash to stock rom and firmware.
If none working, go to service center.
